sky raider mach 1
sky raider mach 1
How do you get the front landing gear rod to go up thru without hiting the fuel tubes coming out of the tank? How far out of the hole should the tank tubes be on the firewall or should the tank lid fit in the firewall hole? First time and not having much luck!!!!!
RE: sky raider mach 1
G'day Mate,
It's easy, just slightly bend the fuel tubes apart, to allow the leg to go though,
see Pix.
Another tip, put the steering pushrod, onto the nose wheel steering arm, & line it up, before you push the nose leg into the mount.
see Pix.
FL
[color=#FF0099]joco,
You are gonna love that plane. One word of advice,.....tape over the entire leading edge of the wing...the coating tends to open up along that seam. (Note: the coating is my only pet peeve on this plane) I've flown the devil out of two of em, and my 2nd one (that went amphibeous) is still flying like a champ!
Bev
Bev
