 Pushrod connectors >
Pushrod connectors
Pushrod connectors
Old 11-19-2007 | 03:01 PM
goirish's Avatar
Default Pushrod connectors
How do you fasten the metal washer on the GP screw-lock connectors if you have to install it on the plane. Is there a tool that will help lock that washer on?
Old 11-19-2007 | 03:07 PM
MinnFlyer's Avatar
Default RE: Pushrod connectors
Remove the servo arm, put the EZ Connector through the servo arm, Place the snap ring on the back, place it on a piece of wood, and tap the EZ Connector with a small hammer and it will pop right in
Old 11-19-2007 | 03:20 PM
w8ye's Avatar
My Feedback: (16)
I have used pliers on them but one has to be careful. The spring washer will want to rock sideways.
Old 11-19-2007 | 03:28 PM
goirish's Avatar
Ok thanks. I have used the x-acto knife handle--it has an opening large enough to clear the pin but small enough to hold the washer. I have problems trying to get them on (for ex. throttle control arm without having to dis-assemble it from the carburator.
Old 11-19-2007 | 03:38 PM
w8ye's Avatar
My Feedback: (16)
This is the norm. You have to get a clear shot at the back side. I have to take the arms off in most cases.
I normally just use these on the throttle servo arm. But I do have some planes that others initially put together that have them all over.
Old 11-19-2007 | 03:48 PM
goirish's Avatar
W8YE--We need to develope a magnetic pliers that will hold the retaining clip and put it on the market. Think we could become very Rich????
Old 11-19-2007 | 03:59 PM
w8ye's Avatar
My Feedback: (16)
I think you could modify existing pliers by just drilling a hole in the jaw?
Old 11-19-2007 | 04:08 PM
goirish's Avatar
That might work if we could just get it magentized so that it would stay on the pliers while trying to install that stupid little clip.
Old 11-19-2007 | 06:38 PM
Villa's Avatar
I don't consider that type of connector safe enough so I don't use it. At the servo I bend the wire into a Z.
Old 11-19-2007 | 06:42 PM
w8ye's Avatar
My Feedback: (16)
On the 40 size and larger planes you should use the heavy duty variety of these connectors and make sure they are tight.
Old 11-19-2007 | 06:43 PM
ORIGINAL: goirish
W8YE--We need to develop a magnetic pliers that will hold the retaining clip and put it on the market. Think we could become very Rich????
good idea but you can make them yourself
you will need:
electric tape
all metal pliers
wires
6-volt battery
im pretty sure you guys can figure it out
thats how i did mine it works pretty well but kinda weak......[rust maybe?]
Old 11-19-2007 | 07:18 PM
E-Mo's Avatar
My Feedback: (12)
As some have mentioned
I take a scrap 2x4 drill a hole small enough so only the pin fit's
place the locking washer on the hole, tap the P.R.C on the washer
work like a charm.
You say they are not secure enough.... ever try to remove said locking washer[:@][>:]
Old 11-19-2007 | 07:22 PM
goirish's Avatar
I was hoping there would be some way to put the retainer on without having to remove either the horn or the control arm. Try to balance that retainer while putting it on a throttle level.
Old 11-19-2007 | 07:26 PM
Ugo Ferrari 's Avatar
I snap on the nylon retainer and add a dab of Canopy Cement to the backside... It won't come off ! Beats fighting the metal retainer ![>:]
Ugo
Old 11-19-2007 | 07:29 PM
goirish's Avatar
fight is right? UGH!!!!! almost makes one lose their testimony
Old 11-20-2007 | 05:02 AM
gunfighterII's Avatar
I'm with Villa, save yourself the aggravation and use a different set-up.
