radio tension
RE: radio tension
I had to put more tension on mine.
I thought having them 'loose' would be less tireing on the thumbs, but I was WAY wrong.
Almost crashed my Somethin Extra cause the 'feel' was non existant.
To try it out I advise tightening them, and testing 'in field' as doing it at the bench I as I found out doesn't give you the same 'sensation' as in the field.
May take a few tries, but it may save smashing your plane into the ground.
My 2c
My 2c
My Feedback: (9)
RE: radio tension
I put a lot of tension on the Aile & rudder. Since I am a thumb and not a pinch flyer it is easier to hold a set amount of throw. For example when doing a fast rolling circle. I am working the elev up and down rather fast. It is easier to keep the roll rate constant if the aile has more tension. An example on the rudder would be Harriers or low hovering. i work the throttle in both of these cases. Having the extra tension on the rudder just gives me better control.
David
David
