 big question >
big question
big question
Old 01-22-2008 | 03:41 PM
Default big question
1st place...hello everybody
i´m a portuguese beginner (my english is not perfect),and i have a big problem...i´m finishing my first r/c plane...the superstearman 40. i have bought this plane in a magazine collection,and i spent 1 year collecting all the parts.Now i´m finishing it,and i´dont know what kind of engine i´should buy!?
can someone give me a hand?
Thanks a lot...i will wait for a answer.
Old 01-22-2008 | 03:44 PM
opjose's Avatar
Default RE: big question
ORIGINAL: Picos27
You can put in an O.S. .46 AX which will give it good power ( though not unlimited vertical ) and is a reliable easy to start with engine.
If this is your first plane, DO NOT FLY IT!
The Stearman while a great flyer, is not an airplane for beginners.
Finish it, and put it away.
Get yourself a trainer and learn on that.
You don't want to destroy your newly built Stearman.
Old 01-22-2008 | 03:52 PM
[/quote]
Thanks for answering...
why do you say that is not an airplane for beginners?
What kind of trainer you recommend?(a cheap one please
the engine that you said,is the right choice for my aeroplaine?
Old 01-22-2008 | 03:53 PM
acarter's Avatar
ORIGINAL: Picos27
Whatevery you do, DON'T FLY THAT PLANE untill you learn to fly a trainer. A biplane isn't even recomended for a second plane, and sometimes can be a challenge for evena third plane. Get yourself a good trainer and an instructor, you won't regret it. I'm not trying to discourage you, but trying to stop you from crashing your plane that you have spent good money and time on.
Now to answer your question an OS .46 fx would make a great engine for that plane and if you want a little extra power an OS 55ax would be good but not nessesary.
Good luck!,
Austin
Old 01-22-2008 | 03:56 PM
acarter's Avatar
ORIGINAL: Picos27
[/quote]
I was typing before you posted, check out rcken's list of good trainers trainers
http://www.rcuniverse.com/forum/m_4537845/tm.htm
Austin
Old 01-22-2008 | 04:02 PM
acarter's Avatar
ORIGINAL: acarter
ORIGINAL: Picos27
Austin
[/quote]
Old 01-22-2008 | 04:04 PM
in portugal...i can buy this one....
http://www.kyoshoamerica.com/airplanes/gp/11215BL.asp
i think that the only one that are selled here,from the list that i saw...
190€
Old 01-22-2008 | 04:06 PM
Old 01-22-2008 | 04:39 PM
Hi I have just started to fly myself and it is not as easy to get to grips with as you may think.
Find a club in your area and get an instructor to give you lessons.
The plane I am lerning on is called ARISING STAR by Seagull Models it comes ARF, fit an engine, servos and radio gear which at a later time when you are flying well move to your next plane.
This plane will all most fly its self[X(], well it is making it more fun learning as it will do as it is told unless I make a misstake.
Good luck but do not be tempted to try and fly your Superstearman as it will take a lot of controlling which unless you are very gifted you will not have at the moment, my instructor has saved me from having to pick up a box full of scrap a number of times.
Old 01-22-2008 | 05:01 PM
acarter's Avatar
ORIGINAL: Picos27
190€
That is a low wing plane, it would be a lot better than a biplane but doesn't really make a good first plane either. It would make a better second plane. If it's all you can buy then your better off gettting that then crashing your biplane.
PS. I have no idea why it posted my reply twice back there
Austin
Old 01-22-2008 | 05:10 PM
opjose's Avatar
ORIGINAL: Picos27
Biplanes require intermediate piloting skills.
A new flyer will crash it quite quickly.
If you try to fly it you can expect the plane to last under a minute.
Don't do it!
The Stearman does NOT have the characteristics you need for your first plane, or even your second plane.
You should only fly it after you have flow a trainer first, then a low wing "tail dragger" second. Even then the Stearman may be difficult for you.
To start out with you want your first plane to be something you will be able to keep under control.
Even a training airplane is a lot for a beginner to handle...
As ACarter posted go to the following link:
[link=http://www.rcuniverse.com/forum/m_4537845/tm.htm]CLICK ON ME![/link]
And look at any of the trainer planes.
You need to start with one of those.
Here is a book you can download which explains everything: [link=http://www.dc-rc.org/bobsmanuals/Bob%20younts%20Principals%20of%20Flight.PDF]CLICK ON ME FOR BOOK[/link]
Old 01-22-2008 | 08:05 PM
bingo field's Avatar
opjose,
Thanks for posting the book, I had run into it awhile back, and couldn't remember where I found it. It is very good at explaining most everything.
