Dubro kwik-fill fueler >
Old 04-18-2003 | 02:35 AM
superfly13_69's Avatar
Default Dubro kwik-fill fueler
Tower Hobbies says the Dubro kwik-fill fueler and the fuel can fitting will work together. As far as I can tell, they don't. Anyone got a solution (besides making an adapter)???
Old 04-18-2003 | 02:12 PM
FLYBOY's Avatar
What do you mean they don't work together? Mine works fine. Your talking to fuel the plane? Put a 1 inch piece of hose on the end of the can fitting if you have to with the quick fueler end on it and plug it in to fuel. Take it off to plug the line back into the can if you have to, or easier yet, put a piece of fuel line on the can so that the fueler plugs into it for storage, and you don't have to take it off and put it on.
Old 04-18-2003 | 03:26 PM
Well, I thought "work together" meant that the probe from the fuel can fitting would work plugging it into the kwik-fill fueler directly. I know I can plug the fuel can probe into fuel tubing, then plug that into the kwik-fill fueler probe, but I specifically got the dubro system because they "work together". Seems that's not the case, eh?
Old 04-19-2003 | 12:03 PM
MinnFlyer's Avatar
They DO work together.
All you need is a piece of fuel line to attach them to each other.
