 General guideline for weights for NIMH batteries >
Old 02-16-2008 | 11:47 AM
Default General guideline for weights for NIMH batteries
Does anyone know of a table for weights of different size 6.0V NIMH batteries?
I have a 2200 mah/6.0V NIMH and it's pretty heavy.
I'd like to know general weights of lower Mah batteries.
No, I do not have a postal scale.
thanks
Old 02-16-2008 | 12:09 PM
acarter's Avatar
Default RE: General guideline for weights for NIMH batteries
What brand battery?
Old 02-16-2008 | 12:17 PM
microsprint9's Avatar
www.cheapbatterypacks.com look at their loose cells and the weight of them and multiply by the number of cells you need.
Old 02-16-2008 | 12:26 PM
Missileman's Avatar
ORIGINAL: jigeye
thanks
Is this a different battery than the 1200mah in your other thread?
If you are worried about number of flights why not use the 2200 mah battery?
I have several 2000+mah receiver batteries 6V and 4.8V. I can't tell alot of difference between anything from 600mah NiCad and 2200mah NiMh as far as my calibrated hands can tell.
Old 02-17-2008 | 07:24 AM
Thanks Missleman,
Just wondering if there were significant weight differences. Apparantley not once I've looked into it. The difference between a 2200/6vnimh and a 1200 v is only a couple of grams. This is from the batteries I ordered at cheapbatteries.com.
