Wheel Collars
ORIGINAL: MinnFlyer
Goldberg doesn't make a 60 size cub.
But if you mean the Goldberg Anniversary Cub, it's a 5/23" collar
I can't testify to the size but I just looked through the instruction manual.
On page 24, although it doesn't state the size of the wheel collar, it does say to drill the wheel with a 3/16" bit.
http://manuals.hobbico.com/gbg/gbga0063-manual.pdf
You can also ask the manufacturer
http://www.carlgoldbergproducts.com/...ort/index.html
Most guys keep a couple of spare 5/32" collars in their part box anyway because their use is so common. Also don't want to be grounded if one falls off or strips.
Done that before. Much like keeping a spare prop with you always.
300 watts from Vultee aircraft 1940 that my dad used. Its a racing iron because it makes the meter spin like a pylon plane in heat. You don,t need that much horsepower though a good 160 or better iron with a heavy tip and use acid core solder not Rosin core. works on 5/32 axles.
John
Rather than just filing/grinding a flat as "safeTwire" suggested, make it a groove (a flat with two sides. The set screw, with Blue Loctite) is LIGHTLY tightend into the groove. The coller will never fall off, and since you did not hurt the setscrew hex socket, you will always be able to remove the setscrew.
