 metal kwik link >
metal kwik link
metal kwik link
Old 02-23-2008 | 01:48 PM
Default metal kwik link
Hi,
im finishing a gws slow stick and decided to change the supplied kwik links for metal ones which can be easily adjusted
this metal kwik links come with a metal threaded coupler and my question is if I must weld this coupler to the piano wire or if it would be enough to epoxy it
im using a 8g micro servo
thanks for your answers,
Monhty
Old 02-23-2008 | 02:25 PM
mclina's Avatar
Default RE: metal kwik link
Epoxy doesn't stick so well to metal. It is better to solder it. I just used z-bends on my slow stick.
Old 02-23-2008 | 02:49 PM
OzMo's Avatar
Several of our club members have found defective metal clevises that either break to easily or have loose pins so beware.[]
Old 02-23-2008 | 03:22 PM
Missileman's Avatar
ORIGINAL: Monhty
Will the wire even fit. The inside diameter of the threaded clevis is smaller than the non threaded.
The non threaded is the solder on clevis.
Old 02-24-2008 | 07:51 AM
MinnFlyer's Avatar
A slow stick isn't going to put much stress on it. Epoxy will work just fine - JB Weld would be even better
