 beginner with battery issues >
Old 03-01-2008 | 04:52 PM
Default beginner with battery issues
i have 2 hobbycity LiPo 2100mah, 30c, 7g batteries. one charged no problem on my polycharge4. the second went through the initial startup sequence but the indicating light went from solid green to 4 red flashes. indicating a fully charged 4 cell battery. i measured the battery voltage and got a reading of 10.6V. i dont believe the battery to be over-discharged because i understand that a cell must be below 3V to be in this condition.
any advice would be great, if theres any way of rescuing this battery as replacements are costly.
thanks.
Old 03-01-2008 | 05:09 PM
Missileman's Avatar
Default RE: beginner with battery issues
Are you balancing the battery?
It is possible for a single cell to be overcharged or over discharged preventing it from charging normally.
There are a couple of good lipo balancers for around the $25 price.
http://www3.towerhobbies.com/cgi-bin...&I=LXMRZ9&P=ML
http://www3.towerhobbies.com/cgi-bin...&I=LXMGS7&P=ML
Old 03-01-2008 | 06:02 PM
Might as well pick up a lipo sack while your out shopping. It could save you a ton of problems.
http://www3.towerhobbies.com/cgi-bin...?&I=LXSEA5&P=M
