Old 09-28-2002 | 03:32 AM
kennedy_simon's Avatar
Default Help
Hi
I'm new to rc planes and need help selecting the right one. I've looked at PT-40 by Great Planes and thought it was quite good in the ARF version. I live in Australia where the exchange rate is about half the US dolar so I'm also on a buget.
For the radio I've thought about Hitec and Futaba and for the engne an OS .40. I'm not sure about 4 or 6 chanels or the LA or Fx series of engine.
Also I try to get RCME and Airborne (Australia) magizines as often as possible.
Thanks for the Help
Simon Kennedy
Old 09-28-2002 | 09:26 PM
Default Thanks
Thanks for the replies.
The Pt-40 sounds, as it's the way to go. I'm also considering getting the thunder tiger pro .46 and a Hitec radio. I downloaded the construction manual and it says you can lock the ailerons in place.
Thanks again
Simon Kennedy
Old 09-29-2002 | 08:21 AM
Banned
Default Help
Sound like a good trainer setup.
The TT pro .46 is an outstanding engine... but open it up and inspect for small metal filings. I was given one that had frozen up due to a bit of mold flashing comming free in the intake and "galling" the crank to the case. (3 hours to repair that. I was lucky it could be fixed at all.) Just pull the carb and the backplate.. flush with a little fuel and any loose stuff will come out. (cheaper to waste 2 to 4 oz fuel than ruin the engine) Done prior to running, the gaskets won't be harmed at all.
Old 09-30-2002 | 04:52 PM
Default Help
Point Noted.
Do you think I should get Futaba or Hitec. I think they are fairly similar.
Simon Kennedy
