Proglow starter >
Proglow starter
Proglow starter
Old 04-26-2003 | 11:35 PM
Default Proglow starter
I bought this http://www2.towerhobbies.com/cgi-bin...?&I=LXJ802&P=K .
trying to start a glow plug with it was going well for the first two times.
Now When I put it on it wont light the plug. I have to not quite put it on all the way and wiggle it a bit till the meter shows me it works. I try when not in the engine to make sure and its the way it is .....whats up?
Old 04-26-2003 | 11:48 PM
either it needs a recharge or the plug is bung
Old 04-26-2003 | 11:56 PM
I have another sub C ill throw in.....because i tried this on multiple plugs.
Old 04-27-2003 | 12:41 AM
JohnBuckner's Avatar
Originally posted by Woodsy
or the plug is bung [/B]
Cool, I,ll will have to remember that down under expression
I have run into a few of the replaceable types that had an intermitent problem and turns out the chrome plated spring inside the cap was just not allowing enough current through. In both of these cases the solution was just to brush both ends of the spring on a wire wheel thru the plateing. These were both near new units with no corrosion.
John
