 thread lock on servo screws? >
Old 03-30-2008 | 09:40 PM
Default RE: thread lock on servo screws?
Btw red can be removed very easily with a bit of heat. Just use a soldering iron in the screw head for a few seconds and its gonna be like there was never any loctit there...
Old 04-03-2008 | 12:36 PM
Flash1940's Avatar
Like most of you that responded to this thread.....I have never had a servo arm keeper screw get even loose......but.....if you're worried about it.....I wouldn't over-kill it with thread lock....instead....a little dob of varnish or fingernail polish on the screw wouldn't hurt....and besides.....when you need to remove the screw, a little acetone will release it. Down pressure with your phillips screwdriver is NOT good.
Flash
Old 04-03-2008 | 01:25 PM
Carefull with the acetone. It will melt many plastics. Used to make plastic cement by putting plastic chips in acetone till it melted. Safer to use nothing.
