 cycling nicd batteries >
Old 04-07-2008 | 07:26 PM
Default cycling nicd batteries
hi,
wondering if anyone here discharges their receiver batteries. Do you just charge and recharge?
iv'e heard it's beneficial to store them at .1 volts or something and then charge them up the night before.
If so what do you use for a discharge rate and what do you take it down to?
thanks.
Old 04-07-2008 | 07:33 PM
Nathan King's Avatar
Default RE: cycling nicd batteries
I discharge receiver batteries once or twice per season depending on use (once at the beginning of the season, once in the middle). Other than that I just recharge them from the last state I flew them in. Any more cycling than that and you're wasting precious cycles. When discharging, bring down the voltage to no less than 1.1 volts per cell (4.4 volts for a 4.8v pack) then slow charge them with the supplied wall charger, unless you have a battery conditioner (then use that). For long term storage I discharge to 1.1 volts per cell and put them in the refrigerator.
I actually just finished cycling my batteries to make sure they were at least 80% rated capacity and ready to go for the season.
Old 04-07-2008 | 07:55 PM
DavidAgar's Avatar
My Feedback: (108)
I also cycle mine. I can say that cycling has saved me at least 5 airplanes by finding bad battery packs. It is good preventive maintance. Good Luck, Dave
Old 04-07-2008 | 08:07 PM
what amp rate do you guys charge at? I have one a digital charger, and it wants me to put in the charge rate. I started at 2 amps, and it got hot. Shouldn't get hot, right? Then when i use it it gets hot some more. Somethings not right here...........
Old 04-07-2008 | 08:28 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
The charge rate depends on the size of the pack. How many Mah is the pack rated for??
Ken
Old 04-07-2008 | 08:35 PM
the one that got hot is rated at 600 mAh.
Old 04-07-2008 | 08:42 PM
RCKen's Avatar
My Feedback: (9)
It should be charged at a C/10 rating, which for your pack should be 60 Ma.
<<Edited to correct typo in charge rate>>
Ken
Old 04-08-2008 | 05:19 AM
CGRetired's Avatar
Umm... please correct me if I am wrong, but isn't C10 = 6 amps? Wouldn't 60 ma be C.1? 60 ma is 1/10 of the 600 mah capacity. C1 would be 600 ma.. so 60 ma would be C.1
I'm not trying to be a wise guy here, just perhaps my understanding of C or Capacity is wrong??
CGr.
Old 04-08-2008 | 06:55 AM
ORIGINAL: CGRetired
CGr.
I'm sure RCKen meant C/10.
It's no wonder that C10 got the thing hot. That's WAY too fast!
Mili = 10^(-3)
Old 04-08-2008 | 04:14 PM
RCKen's Avatar
My Feedback: (9)
ORIGINAL: Nathan King
ORIGINAL: CGRetired
CGr.
Mili = 10^(-3)
Yes, I meant C/10. Trying to do too many things at once and missed that. Guess that's my mistake for this month!!!
Ken
