 Will this work? >
Will this work?
Will this work?
Old 04-28-2008 | 11:21 PM
Default Will this work?
Will a Hangar 9 FS One Flight Simulator Replacement TacCon Controller V1 MD2 work with the FS One SOLO simulator, or is it just for the real FS One?
Old 04-29-2008 | 05:37 AM
CGRetired's Avatar
Default RE: Will this work?
Did you ask this question in the flight sim forum area? Perhaps you can get a faster answer over there. Not that someone won't answer you here, just that the flight sim forum has users that probably will have used that particular sim, or a manufacturer's section that can answer it for you.
I use AFS and GP Realflight 3.5, but the controllers are not interchangeable.
CGr.
Old 04-29-2008 | 03:09 PM
I asked in the other forum about 4 days ago with no answer....
FS One uses that controller, and the version I have is the FS One SOLO. It is the "trail" version they give you with Hangar 9 planes. It is from the same company, but I was wondering if you could use the FS one controller with FS One SOLO.
