Does anybody have this charger?
TX
Does anybody have this charger? I just got it at our swap meet last month and have'nt really had a chance to try it.
No box, but I got wires for both the Tx, and Rx.
http://www3.towerhobbies.com/cgi-bin...?&I=LXL311&P=7
I purchased one about 12 years ago and it was OK for several years untill the peak detection on the Rx side failed and quit working. Finally threw it away.
Keep in mind is not a very capable charger or versatel like a modern one and is OK only for Nicad packs. Uses a single non selectable charge rate and is only good for 4.8 Rx packs or 9.6 Tx packs of about 600Mah capacity. If you use larger capacity packs then this one will not do the job properly.
John
John
TX
I just got it in case I needed it at the field, my rx is 4.8 600mA in both planes and 9.6 in the tx.
Thanks guys
Thanks guys
This is what I have.
http://www.horizonhobby.com/Products...?ProdID=HAN114
I got it last year. Works very well.
I recommend it.
Frank
I recommend it.
Frank
