 lipo balancers >
lipo balancers
lipo balancers
Old 05-24-2008 | 10:55 PM
Default lipo balancers
Are there such things as lipo balancer chargers?
Or do you always have to use a lipo balancer with a lipo charger?
Can someone point me in the right direction?
Old 05-24-2008 | 11:15 PM
Default RE: lipo balancers
Yes there is, but they are higher priced than non balance chargers with more capabilities.
Here's a couple:
http://www.readyheli.com/Kong_Power_...p/kp-100w6.htm
http://www.b-p-p.com/proddetail.php?prod=h_DNCharger
Old 05-25-2008 | 09:06 AM
Campy's Avatar
The most "bang for your buck" will most likely be a regular lipo charger and a separate balancer such as a "Blinky" (or comparable). I know the Blinky can be used both during the charging process or after the battery is charged to balance the cells in the battery.
I use a "LipoDapter" running off my Astroflight 110D and plug the Blinky in while it is charging.
The "LipoDapter" is not for everyone. I already had the 110D and didn't want to spend the extra money for a dedicated lipo charger. It is a "work around" that, for me anyway, does the job at a very reasonable cost.
Old 05-25-2008 | 01:29 PM
Missileman's Avatar
I use the Bantam E-station BC-5.
Not only will it balance charge up to 5S lipos, it will charge all my other RC batteries including my 12V gell cell in my field box.
Great field charger.
http://www.grandrc.com/inc/sdetail/66739
Old 05-25-2008 | 08:20 PM
Thanks for the feedback guys!
Old 05-25-2008 | 10:46 PM
My Feedback: (314)
Try the Cellpro4 at fmadirect.com. This is a balancer charger and adapters are available for the different LiPo packs. Works great.
Old 06-02-2008 | 05:27 PM
cleansho93's Avatar
ORIGINAL: Campy
When you refer to "Blinky" are you talking about the eflite balancing charger with the red and green leds on it (or comparable)? I have one of these and also have the larger 4 LED version that came with my Eflite Blade 400 helicopter.
Are you saying these can be used as a stand alone balancer? I am thinking of purchasing the Electrifly polycharge 4 that will charge 4 packs at once. Will I be able to plug in the blinky to the balance connector of the pack while it is charging on the polycharge and have it balance the cells? Also can the blinky be used independently as a stand alone balancer after you are done charging the pack? And if so is it necessary to use the balancer every time you charge or only every few charge cycles?
Any info will be greatly appreciated. Thanks
Old 06-02-2008 | 08:45 PM
Missileman's Avatar
Astro Flight makes the Blinky balancer,
http://www3.towerhobbies.com/cgi-bin...&I=LXMRZ9&P=ML
