Need help with Airmadillos
PA
Just bought a Airmadillos from the airplane factory.Co. states
can be built in a couple of hours,I don't know about that !
I've built kit models all my life and cannot make any sense
of their Blue Print sheet instructions.If the Air frame would
match-up on the blue print there might be some reference
as to where to start drilling holes.It says to mount the engine
as far foward as possible,but how far ? The tail section is another real treat.What I need is Pictures of the fuse set-up
and especially the tail section if anyone can help thankyou.
Have you e-mailed the supliers or looked at there site? http://www.kombat40.com
Try re posting over at the SPAD or Combat section, some one over there should be able to help with the Armadillo.
once you get the hang of it a 'dillo can be put together in a couple of hours easy, you can scratch build a standard SPAD in about 6 once you get the knack
