Stripped muffler hole
OK so my new motor arrived, gummed up pretty bad and missing a few bolts. (I got exactly what was shown in the picture so not the sellers fault here)
I clean it up and assemble it, after a visit to the hardware store for a couple 4-40 x 1 1/2" bolts for the muffler, an O ring and some set screws for the carb. I get her assembled and discover that the rear muffler bolt will not tighten (Yes I carefully matched the thread s when I bought the new screws). I bought on E-bay, and I'm not willing to return the whole thing over this, so assuming the seller cant help me how can I fix this?
Oh, just so you know its K&B .61 Ringed with what appears to be a Perry style carb. (Whatever that means) I have an .46 Evolutions muffler, but lost the bolts LOL! Would that fit it??
RE: Stripped muffler hole
Can the muffler and engine accommodate a slightly larger bolt? If so, get a 6-32 tap & appropriate drill from the hardware store or hobby shop & re-thread the hole for larger screws.
MA
I have the same problem with one of my engines but with both bolts not tightening, all they do is slip into the holes. I simply hold them in place with hex nuts with threadlock..
If there is enough meat left for enlarging the hole I'd consider a heli-coil repair. Clarence Lee is an expert on these engines and runs a repair/mod service. See if you can contact him. Factory parts can be obtained at http://www.mecoa.com/kb/61/61-parts.htm Perry carb is a great carb, you'll like it. For current carbs or parts see http://www.perrypumps.com/prod01.htm
http://www.craftsmanshipmuseum.com/Lee.htm You'll note that Clarence was the engine designer.
ORIGINAL: mscic-RCU
Redrill and tap for 6-32. Have done many times on KB\HB mufflers.
ORIGINAL: broke_n_bummin
... and if you ever need to do the head bolts, you can tap them out 4mm
ORIGINAL: mscic-RCU
