slight miss when inverted
flying my ultra stick 40 today with a 46 ax in it and when i fly inverted it hesitates slightly when i first flip to the inverted position dont know if my carb is set right i tried the pinch test and it died but didnt speed up any before it did could this be one in the same problem?
My Feedback: (18)
OK
Sounds like it is running lean, from what I have seen at my field, on others and mine too, you want a little speed up in rpms when you pinch the line. This means that you were inducing a lean condition. I think it is already lean if it does not speed up.
If your muffler pressure line is the tank's overflow, then when you go inverted, that overflow suddenly is under water..... uhhh, under fuel. It changes the fuel head at the carb pickup for just an instant. It's one reason Uniflow tanks were invented.
i do have the pressure line hooked to my muffler a two line set up i never had heard of a uniflow tank what do they do or i guess i should ask how are they different than the tank that came with the stick 40 ?
Your tank has a pickup line with a clunk so the pickup follows the fuel at the back of the tank. The other line is the overflow and goes to the top of the tank so that when the tank is filled, that line will overflow when the tank is full. Since the muffler pressure has to get into the tank somewhere, you gotta hook it up to that overflow line.
You could add another line but why not use the one already there for the muffler pressure. After all, it works ok. Well, that's not always true, as you've proven clearly.
Uniflow is a way to get a steadier run from our systems, but it takes an additional line for the pressure. It works steadier by placing the outlet for the pressure into the tank close to the pickup, where the fuel is drawn from the tank. Cut down the distance from where the pressure enters to where the fuel exits, and less things are between the two important locations. There will almost always be solid fuel, and not very much of it, between the pressure in and the fuel out, if there isn't much distance between the two.
So how do you plumb a Uniflow? You run a 3rd line. It'll run from the muffler fitting almost to the pickup clunk. That pressure line can end within about a half inch of the pickup clunk. The line can just end. It can be connected to the pickup line or the pickup clunk. Or it can end as another clunk. (They will both follow G forces and stay pretty much together.) That is what the 3rd line will be. And you'll plug the overflow line except when filling the tank. And you can fill from either the pickup or the pressure lines.
Is it worth the trouble and bother? It's up to the builder/flyer. Depends if your particular airplane/engine/tank/plumbing is giving you trouble or if the flying you do needs a steadier fuel feed.
BTW, I just refitted the plumbing on my H9 Thunderbolt from uniflow to "simple 3 line". The airplane now loses just a bit of RPM over the top of loops etc. I'm going back to the uniflow layout next time I have the cowl off. I don't fly the P47 in precision but I don't really like the slight loss of power. Fueling the plane with a uniflow setup had a problem with siphoning from the layout of the lines inside that cowl, and that was what caused me to decide to try the simple 3 line. It wasn't worth it.
We all decide what's worth the trouble and what isn't. And sometimes have to choose between one bit of trouble versus a different bit of trouble. With uniflow, we have a solution to one bit of trouble.
ORIGINAL: joco1
Yes its too lean. When using the pinch method the idea is to entrichen when it responds to the pinch as above. The whole idea is for the engine to just give a hint of rise on the pinch and that is your sweet spot.
The pinch method is an excellent technique and requires less subjective guess work than by sound and I beleve even better than a tach for two strokes. But it would help to get someone conversant with the method to locally show you what to expect.
Your setting was to lean, suggest you retune and fly agine before making any tank changes.
John
IL
ORIGINAL: joco1
thanks da rock you explained it well i might try it that way you wouldnt happen to have any diagrams of this method?
You are confused too? A picture is worth a thousand words.[sm=confused.gif]
