What causes this?
I have a OS-46 that runs great. The problem is: when I pull the throttle back to idle-the motor slows down, then then after about 5 sec. It slows down more. If I set the idle where I want it when it slows down then it quits. Any suggestions. Like I say the motor runs great, good transition, WOT is good
That is usually a sign of being too rich on the low end.
At WOT the mixture is good but the needle valve is set slightly lean to compensate for the extra amount of fuel coming in from the low end adjustment, so when you throttle up, the transition is good.
Now you go back to idle, and the mixture slowly richens.
Try adjusting the low end by 1/8-turn increments. You'll have to richen the high end slightly each time too
