fuel filler >
fuel filler
fuel filler
Old 05-12-2003 | 11:50 PM
Default fuel filler
i have a du-bro full filler valve with two lines out does it make a difference which one goes to the engine
Old 05-12-2003 | 11:58 PM
Hircflyer's Avatar
Default fuel filler
Yes, if you lost the directions........get the adapter, put a small lenght of fuel tubing on it, insert in filler, then blow in to the fuel tubing, , the side the air is coming out from goes to the tank. The other outlet goes to the carb.
Old 05-13-2003 | 12:22 AM
Default fuel filler
thank you
