 Aluminum Spinner >
Aluminum Spinner
Aluminum Spinner
Old 07-02-2008 | 05:49 PM
Default Aluminum Spinner
I am building a Tiger-60 that has a 4 stroke Thunder Tiger 91-S in it. I plan to build a cowl around the engine and put a 3 blade prop with an aluminum spinner on it.
I have been looking at a couple different sites with spinners and I have just been getting confused. I'm not sure which spinner to get and what size and not sure if it will need an adapter or anything on it.
Help please?
Old 07-02-2008 | 06:28 PM
Nathan King's Avatar
Default RE: Aluminum Spinner
I would say any engine (especially four strokes) over the .82 cubic inch displacement should have an aluminum spinner. You might check Tru-Turn. I have two of their spinners and love them, one of which I had made to order. Spinner size? Whatever looks good.
Old 07-02-2008 | 07:31 PM
Jester241's Avatar
Aluminum spinners need to have an adapter nut. You will need a 5/16 x 24 "long" adapter nut most likely. Tower hobbies sells about any size tru-turn 3-blade props. You will most likely have to grind on it some to get your props to fit( I always do). For some reason all my aluminum spinner needs a spacer washer on top of the prop washer because the adapter only screws on so far,so watch for that.
Old 07-02-2008 | 07:46 PM
I was thinking a 2 3/4" or a 3" spinner.
Can anyone show me a link to which one I should buy and what adapter is needed? Also...any prop suggestions?
.91-S Thunder Tiger 4 stroke engine
