My first covering job!
My Feedback: (18)
OK
Well since I soloed Wed. night, and I won't be flying till next week, I decided to treat my ugly stock Skyraider wings to a facelift. For you new guys that are trying your first covering job, get a good heat gun! I tried it with my wifes hairdryer and it didn't do squat[:-]! I didn't have access to the good heat gun that I can go get, but the iron worked well. It sure looked like garbage before I held the iron to it for a while. The shrinking really takes up the slack and wrinkles great. The center was like an old woman's (you know) until I held the iron over it and shrunk it. This was literally the first time I have ever used this stuff, and believe it or not, its Towerkote! I have to give alot of credit to Minnflyer's videos. They were very similar to what I did on the top surface. The bottom just got a few stripes to give it some character.
My Feedback: (8)
RE: My first covering job!
Looks good, Brett! You will be amazed once you get a proper heat gun. I did some repairs to my plane, and have worked out some wrinkles with the iron. Then I went to my LHS to use his heat gun, and the wrinkles disappear in a flash! It's amazing.
Anyway, your wing looks very good. You should be proud
My Feedback: (22)
IN
Wow, nice job, it really looks great. One question, did you go over the old covering or strip the old off? Did you have any trouble getting the old off? I have an old plane I bought at a sale that I would like to recover and would like to find the best way to get the covering off (that way, I can check for past damage as well).
My Feedback: (18)
OK
I took the old off by heating it with a hair dryer to loosen the adhesive. The bottom of the plane is the original covering with just the stripes added. My plane is new, so I don't know if that will make a difference.
ORIGINAL: brett65
Looks great now. Those planes really aren't bad looking if they'd just do something about the goofy pattern on the covering.
brett65,
Nice job! I've just finished covering a new plane and can appreciate what you've done.
Mine has wrinkles all over, is this normal?
Oly
Oly
My Feedback: (18)
OK
Mine had alot of wrinkles until I stretched it. I used my iron to heat it to the stretching point, but a heat gun would work best. Did you try to stretch it yet. I was amazed at how many wrinkles actually completely dissapeared after stretching it.
My Feedback: (18)
OK
I think it would be best if you could remove them since you could seal all the edges much better. I don't think that it would be a "must" though.
RCU Forum Manager/Admin
My Feedback: (9)
ORIGINAL: brett65
If you are interested in the procedures for covering these surfaces take a look at my LT-40 Build thread as I discuss how to do it there.
[link=http://www.rcuniverse.com/forum/m_3439708/tm.htm]Pay It Forward build thread!! LT-40 build.[/link]
Ken
OR
I have a question on this topic. I am building a Sig 4* 40 and was wondering if I should put the tail feathers on and then cover or cover everything and then attach them after the covering is done. Any suggestions?
My Feedback: (18)
OK
Check out RCKen's thread http://www.rcuniverse.com/forum/m_3439708/tm.htm and you'll prolly get a direct answer from him too in here.
ORIGINAL: gaRCfield
Do you have to remove the epoxied tail pieces to re-cover a plane? I'd like to re-cover my plane some day, but I used a ton of epoxy to hold on the stabilizers.
Just be careful with the x-acto blade near the tail if you need to cut any covering away. If you accidentally score the tail too deep you could create a weak point and cause failure.
