 Electric conversion >
Electric conversion
Electric conversion
Old 07-20-2008 | 08:05 AM
Default Electric conversion
I recently purchased a Hanger 9 Arrow and was wondering if it would be possible to convert this plane to electric? If so what size motor, esc and battery would I need and would it be feasible to do this? Any help would be greatly appreciated. thanks in advance.
Tom
Old 07-20-2008 | 10:38 AM
ChuckW's Avatar
Default RE: Electric conversion
Is it possible? Definitely.
Take a look at the electric forums, i'm sure you'll find some good answers there:
http://www.rcuniverse.com/forum/forumid_227/tt.htm
Old 07-20-2008 | 01:06 PM
CGRetired's Avatar
Absolutely possible. All it takes is $$$ and some information on what engine/esc/battery combination it would take. Oh, you said that.
There are two factors that will determine what combination you want. First is how you intend to fly it, and second is the weight of the aircraft electric equipped.
To start off, you know the weight of the plane as it is now (weigh it without glow engine, battery pack, receiver, and fuel tank). Then esitmate what combination you think it will take after doing some research, of couse. Then compare it to the information on power vs. weight vs. flying style and see if your selected combination matches. It won't hurt to slightly overestimate such items.
Once you are pretty happy with the combination you selected, then get what you need. Electrics will be somewhat lighter than their glow counterparts, of course, depending on where you put your battery pack. So, if it flew before, as a glow, you will have to re-do the CG with the new components.
The troublesome issue in electric conversion has always been weight. Although LiPo technology significantly diminishes this concern, it remains a significant design consideration. Most large electric motors have a weight comparable to their glow counterparts. The Model Motors AXI 2820 series, comparable to .20 size engines, weighs about 6 ounces. The AXI 4130 series, roughly comparable to something in the .60 to .90 (two-cycle) class, weighs about 14 ounces. The batteries are somewhat heavier than fuel, however. I’ll use a typical Kokam 2000 MaH cell for the following illustrations. Assembled into a pack, this cell weighs about 2 ounces. I generally like to power my aircraft to give me a comfortable 10-minute flight (of typical flying with 3 minutes reserve). This requires about three cells for each .10 cubic inches of equivalent glow displacement. Thus, a .20-sized aircraft would need six cells, a .40 size would need twelve cells, and a .60 size would need 18 cells. This is, of course, a starting point; my 3D-capable Hangar 9 Twist only has eight cells, but then I only fly it seven or eight minutes. But, as a rule of thumb, this suggests that the batteries for a .60-sized airplane will weigh about 36 ounces, or about 24 ounces more than the fuel for the comparable glow engine.
Also, take a look here:
http://www.stefanv.com/rcstuff/qf200103.html
CGr
