 trouble setting up my 1st plane >
Old 07-24-2008 | 01:10 PM
Default trouble setting up my 1st plane
Im a heli guy trying to learn to fly planes also. I have a jr 9303 and a addiction 3d plane. My problem is I cant get the aux 2 to move up and down with the elevator when applying downward stick, I got the aleron to do so but I cant get the aux 2, it moves right and left with the aleron but not up or down with the elevator. If anyone has a setup or ideas that would be great Im sure its something simple. thanks
Old 07-24-2008 | 02:26 PM
opjose's Avatar
Default RE: trouble setting up my 1st plane
Go to where you have your mix set up in the menu.
It currently reads something like
Ailer>Aux2
Highlight/underline "Ailer" using "select".
Hit the PLUS key to make it read
Elev>Aux2
instead...
Where you see "Switch" make that read "ON".
Exit out.
Old 07-25-2008 | 03:22 AM
I assume the Adiction's not your 1st plane and you've flown trainers for a while ?????
HavingHeli experince reallly isn't going tp preare you for a 3D plane.
