Venus 40 Landing gear upgrade
My Feedback: (13)
NJ
Hey- Has anyone upgraded their landing gear on the Venus 40? If so could you tell us what you used to replace. Im looking to replace the OEM landing gear with something that has similar specs. I do not like how the wheel pants go on as per factory specs yet the landing gear provided isnt wide enough to mount the pants with small screws and blindnuts. Any help would be great!!! Thanks! Hoping to finally maiden this thing sometime this week.
My Feedback: (13)
NJ
RE: Venus 40 Landing gear upgrade
Has anyone used these before?
http://www3.towerhobbies.com/cgi-bin...?&I=LXFV64&P=7
How are they used? Im assuming They clamp onto the actual axle then using thin ply, I screw then into the wheel pants. Is that right? Really trying to figure this out. If anyone has a pic or a diagram, that would be great.
CA
ORIGINAL: ro347
I used the stock gear and wheel pants using the "cut a slot in the wheel pant technique" outlined in the review on Tower's website. I am at work, otherwise I could post a link. I agree that the stock ones are crap, but I figured I would use them until they have a problem. I still have the LG from my Pulse. When I get home, I will see if they would work. By the way, I have had a few less than perfect landings with my Venus. Even bent the landing gear up a little. All I had to do was bend them back and they are working fine, even if they are crap.
TX
Here is the link:
http://www.rcuniverse.com/magazine/a...article_id=107
CA
