ARF Firewall crooked?
I am nearly done with my new Tiger 60 arf. I noticed the firewall is not square to the rest of the plane and It looks to be on purpose. The hatch covering the fuel tank is also cut at the same angle.
Is this on purpose, and if so why? If it is wrong what should I do to fix it.
Pictures below...The square is flush to the side of the fuse in both, but one side is square and the other is not.
Paul
Paul
RE: ARF Firewall crooked?
Don't worry, the angle is intended. Often, the designer will incorporate various engine thrust angles to improve the flying characteristics of the airplane.
In your pictures, it looks like the blind nuts for the motor mounts are also off-center to the left. This is to compensate for the angle and keep the spinner close to the center line.
It all looks a little weird the first time you see it but the designer knows what he is doing.
ORIGINAL: paully_321
Paul
Paul
Bill, AMA 4720
WACO Brotherhood #1
NE
Right thrust on models is to counter the asymmetrical slip stream caused by our single engine single propeller planes.
Torque, p-factor, etc. really don't come into play.
P-factor is reversed when inverted, which means we'd need left thrust to counteract it. For a real world example, we use right thrust in pattern ships, which spend 50% of their life upside down, yet they track true both inverted and rights side up, so right thrust isn't because of P-factor.
Torque only has a roll effect, not a yaw effect. The torque in most planes is small due to the mass of the propeller is so small compared to the mass of the plane.
Gyroscopic effects can sometimes be felt with abrupt pitch changes or on large enough planes, but right thrust doesn't fix that.
The prop is also spun in the air with a resistance so this torque made on the prop by the engine has to have a counterforce/torque. With a prop spinning anticlockwise the plane will roll clockwise (when viewed from the front) i.e. the plane rolls to the left.
Yes I agree to that.
But it also depends on the plane. Without ailerons but with dihedral in the wing, righthand thrust can be used to counteract this torque rather than using the rudder.
NE
I understand your point, with dihedral, right thrust produces right yaw, which couples to right roll due to the dihedral, which opposes torque. But, I guess should have added that I just don't see how there could be enough torque present to cause a problem in our models. If I understand what you are saying, to counter torque on a non dihedral plane, we would need a throttle->aileron mix to counter torque? Right thrust won't do it since the coupling is gone with no dihedral. So I don't understand why torque is a problem only on dihedral planes. I just haven't ever seen the need for a throttle->aileron mix so unless I'm missing something or misunderstood, I’d think the roll component you are fixing is really yaw from the slipstream that coupled into roll due to the dihedral in the wing, nothing to do with the engine torque.
