no fuel
no fuel
trying to start my 46 ax for the first time (sky raider mach 11) ive got three lines running from the tank and i know they are hooked up right but i cant get any fuel to the carb at all even when i hold my finger over the carb to prime it none runs thru the line........was hopeing to break the engine in tonight and maiden tomorrow ....but i cant get it to start !!!! any ideas?
RCU Forum Manager/Admin
My Feedback: (9)
RE: no fuel
Joco,
Ok, what you need to do is figure out if the fuel can even get out of the tank. The easiest way to check that is to fill the tank, and then remove the line from the carb and the vent line from the muffler. Blow into the muffler vent line and fuel should be pushed out of the line to the carb. If this doesn't happen then you have something inside the tank or the lines that is plugged up. If you can get fuel out then you need to look at the engine. The needle valve may have something in it blocking it. Connect your fuel pump to the carb inlet and remove the needle valve. Close the carb barrel completely and pump a little fuel through it. This should flush out anything that might be blocking that.
Give these two things a try and see what happens.
Ken
Ken
RE: no fuel
If you have three lines they are thustly: (1) line from clunk to carb. (2) line from somewhere to muffler, (3) vent line going to top of tank and plugged after filling the tank through the muffler line. Check and see if this is right. Sounds like you might have the vent line going to the carb.
RE: no fuel
it was the latter of the two rc ken there was something behind the needle valve ,i hooked the fuel pump to the carb after removing the needle valve and felt something go thru,then i put the needle vave back in and turned it over once and she fired right up! thanks very much for the help and by the way, rc ken you have about got me convinced you always know what you are talkin about
RE: no fuel
Problem is that he gives the same answer for questions about loose wheels and other stuff. He had to be right sooner or later. Just like a broken watch is correct twice a day.
MO
RE: no fuel
If you guys keep this up we will have to pass the hat just to buy him a bigger one
Never say anything bad to RCKen....good help is hard to get! Especially at these prices!
RE: no fuel
well i gotta nother RC KEN question since we are on carbs, i was putting together a pulse 60 and it is my first plane to cut a cowl to fit! well after taking my cowl on and off two dozen times i finally got it to fit and i was trimming a little around the carb to get a better fit and i accidently nipped (for lack of better word) the carb and the top of it now has a place out of it ........will this hurt the performance as bad as it hurts the appearance!
FL
RE: no fuel
I just have to ask, what in the world were you using to trim the cowl that could take a chunk of metal off the carb?
It must have been a pair of those scissors which will cut through anything that are advertised at 3 in the morning
RE: no fuel
lol, actually i had the carb covered up with a shop rag ,and was trimming with a dremal and i dont know when i did it, it was like that when i uncovered the carb! i had been taking the cowl off and this time i left it on and trimmed...............it was another one of those great lessons learned!!!
RE: no fuel
So what ya do is, take a tiny v file and clean up that chip and then cross the venturi and make the same notch then do it again 90 degrees and if someone asks,, you can tell them "ya its the rare notched version, only a few of them made, supposed to help turbulate the air"...Rog
