 Tx and Rx >
Tx and Rx
Tx and Rx
Old 10-13-2008 | 01:36 PM
stumpknocker's Avatar
Default Tx and Rx
is there any problems or ill effects from using a Tx with a different brand Rx.
Old 10-13-2008 | 01:42 PM
MinnFlyer's Avatar
Default RE: Tx and Rx
Yes and no.
Some brands are compatible and some are not.
Old 10-13-2008 | 01:44 PM
Provided that it works, no. 72mhz PPM (FM) is really quite flexible. So long as the phase shift of the receiver and transmitter are the same (they're either positive or negative), you're good to go.
PCM and 2.4ghz gear aren't interchangeable between brands.
Old 10-13-2008 | 01:56 PM
i have a futaba T4EXA, so if the rx says its compatible with futaba everything is ok, or is it just better to stay with a futaba rx. thanks for the replies.
Old 10-13-2008 | 02:11 PM
MinnFlyer's Avatar
If the Rx says it's compatible with Futaba, you're good to go.
Old 10-13-2008 | 02:14 PM
Many brands of receiver will work well with that transmitter, most Hitec, Corona, FMA, Berg and.......on and on. As long as they are PPM and negative shift (or selectable shift) they will work.
Old 10-13-2008 | 02:18 PM
thanks for the info, happy flyin.
Old 10-13-2008 | 02:45 PM
If you tell us what manufacturers and what model of radios you are talking about we can be more specific. Right now the answer must be: Yes, no and maybe.
