Cutting Cowls
My Feedback: (17)
This is the first time I have cut a cowl so I neded your advice. What Dremmel attachment is used to cut the fiberglass cowl? Any other advice would be appreciated! Thank you in Advance.
For an expert job.
I tape construction paper to the fuselage (tape it back far enough so you can slip the cowl underneath without taking it off)
cut the needed holes in the construction paper fixing any mistakes as you go. Remove the engine and slide the cowl underneath, mark the holes with a fine tip marker.
Remove cowl and grind away as needed. I use a small sanding drum and a small stone as needed with my Dremmel.
My Feedback: (18)
OK
Yeah, use the thin cutting wheels to make the initial openings. Use the sanding drum to finish it off, and use a slow speed. High speed will take away alot real quick.
To cut a cowl I use the following items:
- Adhesive tape & paper ( as per Missleman )
- Drywall Side cut bit used in hand held dremel.
- Small and medium Dremel Sanding drums
- Hand/Finger drills
- Panel Line marker Pen
- Alcohol to remove the Panel Line Marker lines later.
- Dust mask.
- Shop vac running just next to where cut is being made.
Usually I position the shop vac nozzle inches from the cowl to catch the fiberglass material.
I use a hand/finger drill to drill through and start at the marks I have made with the panel line pen.
The side cut bit is used to enlarge the holes and clear out large areas.
The large sanding drum is used to finish off the larger holes, while the smaller drum for the small openings.
Work SLOOOWLY... check your work OFTEN...
I may take 2-4 hours to cut a cowl with several openings, etc. but the results are worth the time.
After the cowl is cut I usually apply thin CA on the inside of the cut areas to prevent the fiberglass from cracking and to help harden it.
- Dust mask.
I generally use a cone shaped grinding bit. You can use just the tip for fine work or use the larger diameter at the base for removing more material.
