Spinner Size >
Spinner Size
Spinner Size
Old 05-27-2003 | 08:32 PM
Default Spinner Size
Anyone know what size spinner to use on a 46fx os engine being used in an Aircore Colt 40. (40 size plane) This is not in the manual.
Old 05-27-2003 | 11:21 PM
Spinner size is usually determined by the cowl size not engine size. I don't think your plane has a cowl so I'd suggest a
2 to 2 1/2 inch spinner. About right for that engine anyway.
Dennis-
Old 05-27-2003 | 11:23 PM
Default spinner size
The more I read the more I see what you mean.
thanks Dennis
Old 05-28-2003 | 06:13 PM
Like Dennis said, pick one that looks good. This is the only case where size DOESN'T matter.
Tom
Old 05-28-2003 | 07:55 PM
I have an OS 46 FX with 11 x 6 prop, was using a 2" but recently moved to a 2 1/4" because I found it much easier to fit (still had to trim the openings for the prop to fit though - is that normal?).
Dave
Old 05-28-2003 | 08:00 PM
thanks guys! I ordered a 2 1/2" from Tower.
Shipping is getting out of hand there though.
Old 05-28-2003 | 11:46 PM
Yes, trimming the opening is normal.
You do not want the spinner to touch the prop.
Just try to trim even amounts from both sides.
I use 2 1/4 spinners on my 46's.
Bill
Old 05-29-2003 | 02:23 AM
Maybe I won't have to trim the 2 1/2" spinner but after putting together an Aircore Colt, I"ll at least have plenty experience with the trimming part!
