Whats a good case for a X9303???
KY
I just purchased a JR X9303......... What is a good aluminum case to store and carry this transmitter? I don't care for the Dbl case from JR. Send a link if you have one as well. Thanks
I use aluminum cases commonly found at lowes, home depot or menards. they are typically between $20 and $29 bucks each. Have seen them in aluminum and sometimes red and black. They usually come with foam - insert and dividers. Can hold 1 trans and other stuff as well.
My Feedback: (8)
http://www3.towerhobbies.com/cgi-bin...&I=LXL375&P=ML
I bought a 'radio case' and indeed it was a pistol case, so you can try some local sport/hunting shops.
My Feedback: (18)
OK
Walmart has a pistol case for 12 bucks, it can hold two transmitters and has removable foam for customizing the fit. It is plastic though, which is just as good a aluminum unless you plan on dropping it out of an airplane.
