non-steerable nosegear >
Old 05-28-2003 | 05:52 PM
Default non-steerable nosegear
Dumb I know but can you successfully steer a fixed nose gear with the rudder? Just taking more room?
Jon
Old 05-28-2003 | 05:56 PM
"depends", but yes, in theory you can. You might find a combination that won't turn though, I'm sure it will vary plane to plane.
Old 05-28-2003 | 06:08 PM
I've flown a Global Superfly ARF that had a fixed nose gear screwed right to the firewall. It was VERY SUPRISING how well it taxied on the ground. That's about all that plane did well.
so yes...it actually works better than you may think.
Old 05-28-2003 | 09:43 PM
FLYBOY's Avatar
Just hold full up elevator to keep the nose wheel as light as possible. If your on grass it will be tougher, but should work some. I don't have steering on a tail wheel plane and hold down elevator to steer it. Just full down and a bit of power. Comes right around.
Old 05-28-2003 | 11:23 PM
A guy at our club has a scratch GA8 airvan with fixed nose wheel and no rudder, he can ground steer it with ailerons, elevator and short busts of power
