 info on hitec reciever >
Old 12-02-2008 | 07:53 PM
Default info on hitec reciever
just bought a new hitec laser6 radio with a hitec supreme IIs reciever, the reciever does not have + or- marked on it . my question is which is ground or does it matter as long as all are on same.
Old 12-02-2008 | 08:12 PM
JohnBuckner's Avatar
Default RE: info on hitec reciever
The black wire on the power and servo plugs always line up closest to the outside edge of the Rx. Champhered two corners on the plug do offer some resistance to plugging backwards but they can still be forced to plug backwards.
John
Old 12-02-2008 | 09:46 PM
tkanks johnbuckner for the quick reply. the plugs do have a small chafer as you indicateded, but offer no resistance at all. they slip in very easily. this is confusing to someone who has not done much of this. but thanks again for you help.
Old 12-02-2008 | 10:18 PM
w8ye's Avatar
My Feedback: (16)
It doesn't work if you hook it up backwards
Old 12-03-2008 | 08:37 AM
There may be more problems than not working if it's in backwards. I connected a battery backwards on a Futaba receiver and had a dead short that almost instantly destroyed the battery. Check carefully before connecting the power.
Chuck
