 Dihedral Question >
Dihedral Question
Dihedral Question
Old 12-05-2008 | 04:14 PM
MetallicaJunkie's Avatar
Default Dihedral Question
I almost to the point where i will be gluing the wing skins onto the foam core halves... the plans called for a specific amount of dihedral, which isnt built into the foam cores.....
It would probably be best i sand in the dihedral into the cores before the wing halves are sheeted? or should i do all of that work after they are sheeted? this is my first jobber like this
Old 12-05-2008 | 04:37 PM
Default RE: Dihedral Question
You can do it either way. You can cut the cores with a hot wire if you do it before sheeting and that might be a bit easier.
