 O.S 91 FX on a Showtime 50 (Learning 3D) >
Old 12-15-2008 | 02:17 PM
plugin's Avatar
Default O.S 91 FX on a Showtime 50 (Learning 3D)
Is it a complete overkill to use the 91 FX on the H9 Showtime 50?
Old 12-15-2008 | 02:28 PM
w8ye's Avatar
My Feedback: (16)
Default RE: O.S 91 FX on a Showtime 50
Not really. People use Saito 82s in Show Times all the time. The power of the 82 and 91 are very close. The 81 just weighs a little more.
Old 12-15-2008 | 07:18 PM
plugin's Avatar
The Saito website states that the 82a weighs 462 grams, but they do not specify if that includes the muffler which I assume is not that heavy in a 4 stroke. The 91FX weighs 688 grams which is more like a Saito 125.
I was absolutely convinced that 3D was not my thing but lately I've been thinking that I could give it a shot. From what I've read, the 3D Trainer by default must be a U-Can-Do. I don't like the looks of that plane. Is the showtime a good idea or will it be out of the question for learning 3D?
Old 12-15-2008 | 08:30 PM
w8ye's Avatar
My Feedback: (16)
Though the "Show Time" and "You Can Do" are designed drastically different, you would like flying either if you are a little bit 3D inclined
However, if you are fast fly-by guy . . . Stay away
Old 12-15-2008 | 08:53 PM
plugin's Avatar
Default RE: O.S 91 FX on a Showtime 50 (Learning 3D)
I have most certainly been bitten by the "fast fly-by" bug. It gets easier by the minute and now that I can do it upright, inverted, on a knife edge, and so on, its taking the form of boring. Nevertheless I want to broaden my spectrum of abilities and this is the reason I want to give one of these two planes a try.
Old 12-16-2008 | 03:28 AM
MetallicaJunkie's Avatar
i used to have a ST 50 a while back, i initially had a 61 fx on it and it flew great, would hover at about half throttle, i then installed a saito 91, it flew greeat, but started losing power("needs to be overhauled"), after that i tried a super tigre 90 man it was fast. I ended up taking it off because i didnt like te look of the stock exhaust, and in the end i would up putting the 61 fx with bisson pitts back in it, and flew the right winf off it.
Old 12-16-2008 | 11:55 AM
plugin's Avatar
There's been a shift in the direction of my interests. I've learned that the best 3D trainer would be a MOJO and apparently the .60 size would be suited with my .91 FX.
