Hobbico Charger
GA
I have a Hobbico Quick Field Charger Mark II that I use to charge all my batteries. I'm charging a Ni-Cad 1.2 volt 2800 Mah. Verything goes ok for several hours then I get the beepping and the alternating green and red light. I understand what the lights mean but why does everything go ok for several hours first. I've had this happen to other batteries only to reset and verything work ok to the battery receives its full charge and the light just flashes indicating that it's in the trickle charge mode. Thanks for the help.
chopper
chopper
CA
It just has an internal timer. If it doesn't peak within the time limit, it stops and beeps and lets you know. Turn up the amperage so it charges quicker, or figure out why it didn't peak. You can charge a NiCd that size at power well above what that charger can put out. That's been a dependable little field charger of mine for years.
