 os 120 4stroke tank vent >
Old 12-30-2008 | 06:30 AM
Default os 120 4stroke tank vent
hi guys,
im fitting out my first os 120 pump fed 300s extra and im wondering what i do with the vent line,do i put fuel line on the tube that comes out the tank and feed it to the top or bottom of the cowling????
Old 12-30-2008 | 07:37 AM
Default RE: os 120 4stroke tank vent
are you talking about the nipple that is on the engine crank case? ....if you are..a piece of fuel tube as you mentioned...I have tie wrapped mine to the exhaust deflector....works well for me
Old 12-30-2008 | 07:48 AM
DavidAgar's Avatar
My Feedback: (108)
It is a vent that you will want to bring out the bottom of the cowl. You can tie it off some how, however the tubing needs to remain open as it is a vent. Good Luck, Dave
