 SIG Balancer >
SIG Balancer
SIG Balancer
Old 01-25-2010 | 07:59 AM
My Feedback: (15)
Default RE: SIG Balancer
Hey w7ye - Yes I balance low wing planes upside down. This plane in question is a mid wing plane.
Old 01-25-2010 | 10:25 AM
JohnBuckner's Avatar
Agine not all airplane configurations are clearcut as to which way it needs to be balanced upright or rightside up, try both and use whichever is easiest. Do not expect it to balance at any other position other than perfectly level.
John
Old 01-25-2010 | 01:31 PM
My Feedback: (15)
Thanks for the info John. So just to make sure I understand the plane should be parallel to the floor. Not leaning fwd or aft.
Old 02-19-2010 | 11:41 PM
whitehawk's Avatar
Hey guys, I too bought this balancer and have a couple of issues. First of all, the holes for the rods are too small so I assume that I'll have to slightly enlarge them, or maybe put wax on the rods ?? Next, I too broke one of the arms and one of the pointers...and I was not being careless! Does anyone know if Sig will replace these? I also noticed that my kit is slightly different as compared to the pictures on the box. Seems like for $40 alot of the assembly should have already been done.
Old 02-20-2010 | 01:15 AM
My Feedback: (15)
Hey WH - I to had to enlarge the holes in order to get the rods to slide in freely. I was fortunately able to build the sig balancer without breaking any parts but I totally agree. For $40.00 it was quite a bit of building to do. I am one for building but I stuck to it and got it done. Its not very difficult once you start it. Just make sure you have all necessary tools handy.
Old 02-20-2010 | 01:46 AM
  #31
jimmyjames213's Avatar
i dont understand the point of a a balancer, unless you are balancing a very sensitive airplane and even then.
the majority of the balancing should be happening at the field. set your plane around the manufacture c.g. then go to the field and fly the plane.
pull up at a 45 degree angle and roll inverted. if the plane falls its nose heavy, if it climbs its tail heavy. then add sticky weights at the field till it flies how you like it. when you get back home move components around to counteract for the sticky weights then take em off. i guess you could use a balancer for the measure c.g. then take sticky weights off and move stuff around part, i just use my fingers
what ever floats your boat
Old 02-20-2010 | 04:36 AM
  #32
whitehawk's Avatar
ORIGINAL: jimmyjames213
Well, since I've only been in this hobby for two years now, I'm using the balancer to initially check COG. Frankly, your method makes sense and I'm only wondering why I have'nt read that before! Good tip, that one is going in the ol' memory bank.
Tim
Old 02-20-2010 | 06:44 AM
  #33
goirish's Avatar
I have to somewhat disagree with Jimmyjames and checking the CG in flight. If it is very tailheavy you won't get a chance to do what he suggested. You will be chasing the plane all over the sky and if lucky getting it back to ground in one piece. Do the recommended CG when building, then, take it to the field and fine tune it for your style of flying. Just a though
