Pule 40 Skis
Does anyone know if there are a set of skis that fit the pulse 40? I know it has wheel skirts, but I would imagine you would take them off, I have the Maiden skis now and love them, would the maiden skis fit on the pulse? Thanks fellas.
The Dubro 40-60 skis work well. Buy another aluminum or fiber gear and set the skis up on that. Then you only need to remove a couple of bolts from the bottom of the fuse to switch gear.
