Sig LT .40 with OS .40fx >
Old 06-05-2003 | 07:24 PM
Joe Ortiz's Avatar
My Feedback: (75)
Default Sig LT .40 with OS .40fx
Is this a good combo, will the engine have enough power?
Joe
Old 06-05-2003 | 07:28 PM
Yes, Plenty.
Old 06-05-2003 | 08:35 PM
Default LT -40 with OS 40 FX
I've had experience with several LT-40's. Great trainer/flyer! Yes, the OS 40 FX will be plenty of power. The OS 40 LA and the older FP engines are kinda weak though. Hope this helps.
Old 06-05-2003 | 08:50 PM
Joe Ortiz's Avatar
My Feedback: (75)
Thanks for the replies, I just bought a brand new .40FX and a LT-40 kit , since I like to build, I was hopeing that this combination was adequet. I'm back to building, and flying soon, after a 15 year layoff from the hobby, I'ved been on this site awhile gathering all the information I can get, it seems that the LT-40 is a good choice for a trainer.
Joe
Old 06-05-2003 | 09:39 PM
An excellent choice for a trainer. Many at our club have learned on them, with lots of engines. OS40Fp, & FX, one tried a 40LA but soon changed to a 46LA, TT46 and another I don't remember.
Dennis-
Old 06-05-2003 | 09:46 PM
Joe Ortiz's Avatar
My Feedback: (75)
I feel better in my investment, now I just need to get a good computer radio so that I can use it in future models.
Thanks Joe
Old 06-05-2003 | 11:11 PM
Live Wire's Avatar
Joe
Great choice , Now a Hi tech EL. radio and you have it made.
Old 06-06-2003 | 12:08 AM
vkernus's Avatar
I am flying the LT-40 with a .40LA and a 11X6 prop (for Break in). While I plan on moving up to a .46FX once I gain some confidence, the .40 has plenty of power for a beginner pilot. IMHO
Old 06-06-2003 | 11:52 AM
Joe Ortiz's Avatar
My Feedback: (75)
I have my radio choice narrowed down, I don't want to mention it cause it might start a radio war
Old 06-06-2003 | 02:43 PM
I doubt you'd start a radio war. Yeah, there are a lot of opionions, but it's not a huge deal one way or the other.
Actually, the one recommendation I'd make is check with your local instructors and make sure they have a buddy box that will work with your radio set. I happen to fly mostly JR, and I appear to be the only instructor at my club with a JR trainer cord, everyone else has Futaba.
I also have a Polk radio that doesn't have a trainer function, and a Tower/futaba system.
Hitech can work with Futaba, but I've heard that there are some issues with weither it's a Futaba or Hitech cord connecting the two transmitters when you mix them. Haven't done it myself though.
Old 06-06-2003 | 05:09 PM
Joe Ortiz's Avatar
My Feedback: (75)
Yea, I know, I'm waiting to check out some of the local clubs to see what they are flying on before I make a purchase.
Joe
Old 06-06-2003 | 05:49 PM
I'll second that. Probably the best out there. I put an Irvine .39 in mine. Power is more than adequate...
Old 06-06-2003 | 11:08 PM
Default LT as trainer.
Good choice. I was given the LT40 kit as gift. Put .46 Fx in and learned to fly. After first wreck put an old OS 32 Fabc in it and could hardly tell the difference in performance. Good luck
Old 06-07-2003 | 01:12 AM
Hircflyer's Avatar
Mine must have over a hundred flights on it and it's still going strong. I fly it every once in a while just to have a change in pace and have some fun with it.
OS .46 still running strong a good combination.
Old 06-08-2003 | 04:52 AM
YS 63 on Lt40. Plenty of power. Saved my plane several times. Full power up elevator. And away it went out of trouble.
Old 06-08-2003 | 07:51 PM
Rcpilot's Avatar
My Feedback: (78)
Being a local pilot and flying at about 6000'-- I can say for sure that you don't have enough engine.
It's going to take at least a good 46 to fly your plane decent. An FX 46 or a TT Pro 46 would have been a better choice. You won't be able to do a loop with that engine. And if you get into trouble- you won't have the power you need to get out. If you need to abort a landing- then you might be in trouble.
Sorry to burst your bubble- but thats an honest answer from a guy who flies in Denver. Been flying for about 5 years now and I've seen plenty of underpowered trainers. Not pretty.
What hobby shop sold you that plane and engine combo?? You should try to exchange it for a bigger engine.
If you decide to keep the engine and fly with it; then be mindful of your airspeed on landing approaches. If you go to abort a landing- then power up and give it a chance to gain as much airspeed as possible before pulling back on the elevator. Keep your climb angle as low as possible or you will stall. You just don't have enough engine to horse the plane off the runway or make any sudden moves at low altitude.
Good luck
Old 06-09-2003 | 12:19 AM
Joe Ortiz's Avatar
My Feedback: (75)
Rcpilet, where do you fly at, maybe we can meet sometime.
Joe
Old 06-09-2003 | 03:25 PM
Whoa, I didn't notice your location, Joe. I've not flown at 6,000ft, but what Rcpilet is right on, you do need more power at altitude.
I flew once last year at a field that is about 1,500ft above my normal, and even that was noticeable. Not a big deal, but noticeable.
Old 06-10-2003 | 01:38 PM
Joe Ortiz's Avatar
My Feedback: (75)
Default ARRRGGGGHHHH!!
Ok, I'd better take the advice of the experienced, I don't want to loose a plane for being under powered, will a .46 FX do the trick?, and will my .40 FX work in another plane like the 4*40 at high altitude?. This will probably set me back a few months, but oh well, better learn it the right way.
Joe
Old 06-10-2003 | 01:55 PM
I think the 46FX would be better suited to the 4*40, I definitely wouldn't go any less than that (at your altitude). A Great Planes Super Sportster 40 built from a kit is very light.....the .40FX might work on that....maybe RCpilet has experience with this combo at your altitude?
Old 06-10-2003 | 01:57 PM
My Feedback: (47)
Default 40FX
Hi Joe, If your going to keep the 40, go ahead and use it. It may do fine with something like an APC 11X4. Then if you get a 46FX it will bolt up in the same holes. I have a nice used OS46FX for $80 shipped. If your interested, you can e-mail me for details. If your a Super Tigre fan I also have a "NEW" 51 ringed for $95 shipped.
Fred [email protected]
Old 06-10-2003 | 06:00 PM
Joe Ortiz's Avatar
My Feedback: (75)
Fredscz, thanks for the offer, but my plane budget is busted right now.
Joe
Old 06-10-2003 | 07:59 PM
Tweet's Avatar
Hi Joe,
You probably should find a way to get a .46. I am flying an LT-40 with a Magnum .46 near Fort Collins and on a hot day (high density altitude) the climb performance is okay, but not great.
I think on cool days the .40 would be okay, but you might be happier with the extra power in the end.
Good luck. I'm really enjoying my airplane so far.
Old 06-10-2003 | 08:29 PM
Joe Ortiz's Avatar
My Feedback: (75)
I'll get the .46, right now I need to build the plane, the left wing is on the building bench as I write this, so, any plane sudgestions for the .40FX?
Joe
Old 06-11-2003 | 11:01 PM
Tweet's Avatar
Joe,
I was flying my LT-40 with the Magnum .46 today (about 80 degrees F) and really it flew with plenty of power to spare. I asked around the last couple of days and apparently a lot of guys do fly the LT-40 with a .40 engine.
So, do what you think is best. The 40 would probably provide adequate, if not overwhelming, performance.
