How to hold my prop on?
MA
Problem has arisen: I can not use a [link=http://www3.towerhobbies.com/cgi-bin/WTI0095P?FVSEARCH=prop+saver&search=Go]prop saver[/link] as it will not fit behind the propeller without pushing it out past the shaft end. And I can not use a [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXMSG2&P=ML]prop adapter [/link] as all I can find that fit’s the motor’s 3mm shaft has a 5mm shaft on IT, which is too big for my 3mm props.
The motor is a [link=http://www.ncweb.com/biz/dan/24Gram.htm]THE BLUE WONDER[/link] 24 gram Brushless 2712-12
What to do???
What to do???
