HS55 servos
RCU Forum Manager/Admin
My Feedback: (9)
If you are installing them in an electric powered plane you don't need the grommets. The main purpose of servo grommets are to isolate the servo mechanism from the vibrations caused by the engine. With electrics these vibrations aren't an issue. Mount them with a screw. Many instruction manuals for park flyer size planes will also instruct that you can glue the servos in place with CA adhesive. However, I myself don't like that option.
Ken
Ken
My Feedback: (19)
NY
If you are talking about the metal grommet you don't need it. It's only purpose is to keep ham fisted modelers from over tightening the rubber part. As OzMo says the rubber part can be simulated with a short piece of fuel line.
Banned
My Feedback: (9)
ORIGINAL: Deadeye
I will also add that hot glue is an excellent method of attaching those little hitecs in a foamy.
Just thinking the same thing...
I got just a wee bit carried away one time w/ the foam safe CA and some of it seeped into the upper part of the case and got into the gears...[:@]
If you're using your 55's in an elec. powered airplane, you don't need grommets.
ORIGINAL: Stripes
ORIGINAL: Red Scholefield
Be careful of that hot glue. I have seen people deform the cases on the servo to the point where they wouldn't work.
ORIGINAL: Deadeye
By the way, what's nice about using the hot glue is that, in the event of a complete destruction crash, you can pull the hot glue off. It takes a little effort, but it comes off. Don't ask how I know that..
My Feedback: (19)
NY
ORIGINAL: bruce88123
The metal grommet is typically referred to as an "eyelet". It's purpose is as described. The rubber portion is a grommet.
ORIGINAL: Stripes
http://www.merriam-webster.com/dictionary/grommet
http://www.merriam-webster.com/dictionary/eyelet
http://en.wikipedia.org/wiki/Grommet
(Edited to get my words out of the quote)
