 Li-Po question >
Li-Po question
Li-Po question
Old 02-14-2009 | 09:20 PM
Default Li-Po question
Hi all,
I was looking at this charger [link=http://www.electrifly.com/chargers/gpmm3015.html]http://www.electrifly.com/chargers/gpmm3015.html[/link]
at the bottom in the specs it says :
Battery Capacity Range: 300 - 3000mAh
now I know thats because it can charge upto 3000mAh, but If I were to try and charge a 4000mAh pack, would that screw up something to the charger and/or pack? or will it just charge the pack at 3A instead of the 4A that it can handle and everything will be ok?
I am just overly cautious with all the lipo warnings
Old 02-14-2009 | 09:51 PM
CGRetired's Avatar
Default RE: Li-Po question
I would stick to the recommendations for that charger. It's not a charger issue, but a LiPo battery issue. LiPo batteries don't handle trickle charging very good, and if that charger was to go to some sort of trickle charge situation because you exceeded the specs, well, you could have a problem
When it comes to LiPo batteries, well, I would be very cautious. Either switch to batteries within the chargers capabilities (possible suggestion) or vice-versa.. switch chargers to match your battery requrements (recommended).
CGr
Old 02-14-2009 | 10:27 PM
ChuckW's Avatar
Looking at the specs, I'd think they just say 3000mAh because it can only charge up to 3.0A. You could charge a larger battery with it, just at less than 1C.
Have you taken a look at the Acucell-6 from Hobby City? It is very inexpensive and charges up to 5A. I have one and it is now my favorite lipo charger. http://www.hobbycity.com/hobbycity/s...lancer/Charger
Old 02-15-2009 | 01:58 AM
brett65's Avatar
My Feedback: (18)
ORIGINAL: ChuckW
+1 on this charger! I love it, and it is easy to program and use. It has a nice digital display that more expensive units don't have. It's requires a 12V source, so you will need a power supply or a 12V battery.
Old 02-15-2009 | 11:32 AM
ORIGINAL: brett65
ORIGINAL: ChuckW
Cool thanks for the info guys, it's actually cheaper if I buy 4 of them then the 1 charger haha
but as for a power supply, what do you mean, like a computer power supply? I can't plug it derectly in the wall or it doesn't have that connector?
Old 02-15-2009 | 11:55 AM
mclina's Avatar
The charger just has a pair of alligator clips that need to connect to a 12V source. I use my car battery mostly, sometimes my field box for a smaller pack.
You can get some type of 12V power supply, but it needs to be capable of putting out 5A or more of continuous power. You also need to be very careful if charging indoors. Do not ever leave a charging LiPo unattended.
Good luck
Old 02-15-2009 | 12:00 PM
Gotcha !
Battery car it is
thanks
Old 02-15-2009 | 12:24 PM
ChuckW's Avatar
I also use an old car battery. I went out to the bin of used batterties at work and tested a bunch until i found a good one. A lot of guys at the field use a small 12V 35Ah deep cycle battery. It is a lot lighter to carry around.
You can also buy a 12V power supply at Radio Shack or other electronics stores but good ones can get expensive.
Hobby City has osme power supplies too:
http://www.hobbycity.com/hobbycity/s...y_for_Chargers
http://www.hobbycity.com/hobbycity/s...100~240V_12.5A
http://www.hobbycity.com/hobbycity/s...ly_100~240v_5A
If you buy from Hobby City, the shipping from Hong Kong can be pretty high on just one item. It pays to order a number of items because the shipping is usually the same.
Old 02-15-2009 | 12:41 PM
cool thanks for the links.
I was thinking at first to buy 4 chargers, but I think i'll jut buy 2 of them and 2 of the GTpower SuperCon power supplys in the link you sent me... I'll try and be patient by waiting 2hours for my batteries instead of 1
great help guys
Old 02-15-2009 | 02:22 PM
I found this... could I put 4 chargers on this? [link=http://www.amainhobbies.com/product_info.php/products_id/5070]http://www.amainhobbies.com/product_info.php/products_id/5070[/link]
it says max amps 23, so I could charge 4 batteries on 4 chargers at 4 amps each and be ok right?
Old 02-15-2009 | 07:39 PM
ChuckW's Avatar
23A is a lot so it might work.
Old 02-15-2009 | 09:39 PM
beau0090_99's Avatar
Before you buy so many chargers, think about what you are charging. If you are doing 2200 mah 3S lipos, you can buy a 6S Y connector from Hobbycity and balance charge two of the same packs at the same time charging at about 2 amps with the Accucel. It would be about 50W / 22.2.
I have been contemplating doing this if I decide to convert one of my .40 ARF's to electric.
Good Luck,
Curtis
P.S. I also have the Turnigy Accucell and love it.
Old 02-15-2009 | 09:42 PM
Instead of buying a power supply, if you have any soldering skills, check out some of the PC power supply conversions that have been done. I asked a coworker for one (he is an egghead), and he gave me a 250W power supply. I just took the cable and found out what connections to short, and which ones to make into + and - leads and within about an hour, I had a supply that will give me nearly 20A of 12v DC power for my charger(s).
Curtis
Old 02-15-2009 | 09:48 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
ORIGINAL: beau0090_99
Curtis
Here is a good How-to on converting a PC power supply for use in our hobby. I've got 6 or 7 of these floating around my shop that I use all the time. I own a computer shop, so I've got plenty of supplys laying around to work with. If you need a supply stop by a computer shop and ask them if they have any power supplies from dead computers. Explain what you need it for and there's a good chance you'll pick it up for free, or for very little money. Of if you have a computer that dies, salvage the power supply out of (if it's still working of course) before you toss the computer.
[link]http://www.marcee.org/Articles/PCPowerSupply.htm[/link]
Ken
Old 02-15-2009 | 09:52 PM
Check the FMA 10S charger. Can charge 2 batteries at once either NiCd NiNm or Li Po. Do need a power supply though. Check the batteries and chargers forum for info.
Old 02-15-2009 | 10:00 PM
Good Luck,
Curtis
I actually have 4 4000mah packs, thats pretty much why
Old 02-15-2009 | 10:01 PM
ORIGINAL: RCKen
Curtis
Ken
cool, even better. I work in a PC shop as well.... I might just "borrow" a couple
Old 02-15-2009 | 10:13 PM
You might want to try this one instead.
I would assume you could parallel balance charge those 4400 Mah batteries at 4.4 amps. Probably more cost effective to buy 2 of the 50W.
Curtis
