OS Carb
Yes.
You can ( and should ) look up the bolt hole dimensions on the Tower Hobbies site to double check.
The .46 AX uses the SAME bolt hole size and hole pattern as the Tower Hobbies .46 engine too.
I have the .46 AX on a little .40 Polecat using a Macs muffler I had originally purchased for a T.H. .46 engine which matches the FX .46 pattern.
