What is the best way to paint EPP foam?
What do you recommend to either paint or spray EPP foam with? Needless to say, I'm sick of the current scheme on my plane. Is there anything I can get at Wal-mart? Thanks again!
My Feedback: (18)
OK
First of all, get a piece of scrap to test on. I tried some plane ol wal mart spray paint and it ate a hole right through my scrap piece of foam. I ended up using testors spray paint for models. It is made to be used on a large variety of surfaces, and I painted my foam phase 3 F-16 with it. Krylon makes a can of paint called "short cuts" and it says it is foam safe, but always test first. Buy a cheap piece of hobby foam from the arts & crafts store if you have to.
MD
I have several EPP planes, and have found no paint or glue that attacks EPP. I have used Ace Hardware cheap spray paint in the past, but currently use water based airbrush paints.
