 4 CH setup >
4 CH setup
4 CH setup
Old 03-19-2009 | 12:48 AM
sportrider_fz6's Avatar
Default 4 CH setup
this may be a dumb question but... I started flying with electric planes and since have switched to glow. here's my question on my 6ch RX there is a port for the batt, on the 4ch RX I was going to use there isn't one, last time it was used was in an electric and I under stand the RX is feed through the ESC. using the same setup in a glow plane where 4 servos are needed how do you power the RX? I was guessing a Y cable?
Old 03-19-2009 | 12:58 AM
JohnBuckner's Avatar
Default RE: 4 CH setup
All Rx's have a common power buss and the power can imput from any of the ports does not matter. Many Rx's to save weight do not have a dedicated batt port so if all channels are used any port is shared with the battery through a standard Y chord.
John
Old 03-19-2009 | 01:03 AM
thanks, I figured it was probably that simple but sometimes I like to over think things
Old 03-19-2009 | 01:08 AM
Its not a "dumb" question and there has to be a first for all of us
John
Old 03-19-2009 | 01:42 AM
Korps's Avatar
And today I learned something new aswell
