elevator does not go up more than I would like...
IL
I have Hangar 9 Easy Fly 40 trainer and the elevator does not go up as much as I would like. It goes up just enough to be operational but with a higher throw I would feel more comfortable. The radio adjustment does not make it go any further so the only solution would be a mechanical adjustment. I'm using the middle hole on the servo arm.
Thanks for any help!
Either move the pushrod out to last hole in the servo arm OR put the push-rod in the hole closes to the Stab. Either way will give you more throw. If doing one or the other and it does not give you the throw you want then do both. Outer hole on servo arm and shorest hole on the stab.
Per Mxaexm: "Elevator does not go up more than I would like".
Sounds to me like you got'r just right then!!
ORIGINAL: MinnFlyer
I was going to say the same thing
ORIGINAL: Mode One
IL
ORIGINAL: bruce88123
I saw that too but was being nice today.
ORIGINAL: MinnFlyer
ORIGINAL: Mode One
It's enough for take off etc but should be more...
Anyway thanks for your help and for being nice today
ORIGINAL: mxaexm
Honestly guys it should go up a little bit more (and its not only my opinion!)
ORIGINAL: MinnFlyer
ORIGINAL: Mode One
IL
Anyway, we can close this post. I got the info I needed so there is no reason in debating.
As always, Thanks you very much for your help...!!!!
