Muffler Gasket????
My Feedback: (18)
OK
ORIGINAL: Rodney
The biggest problem with two piece mufflers failing (the ones with a long threaded rod from front to back holding them together) is not vibration. It is the fact that the thermal expansion of the long rod is quite different from the muffler body. This constant expansion/contraction effect from the heat of combustion then cooling off stretches the threaded rod and lets the junction become loose. There is no amount or type of sealing material that will correct this fault as it is just a poorly engineered design.
The better the system is sealed, the more consistant the engine runs. The more demanding your chosen flight program is, the more that little details like having a perfectly sealed exhaust becomes.
It's usually not a big deal to a sport flyer, but it can make a difference.
Hi Rodney
I have never had a muffler thru rod break. Every one of my mufflers has one. I make certain that nothing is ever loose on them. According to your theory, the head bolts should also break. Or the muffler to engine bolts. I have seen other people break the muffler thru bolts. They seem to be the same people who do nothing about the muffler being loose unless it falls off, once, twice, three times. The "if it does not break, why fix it" philosophy. To each his own.
ORIGINAL: Villa
Hi Rodney
Hi Rodney
The reason they don't break is because they're tightened when cold and contracted. If you had the engine at running temperature and did up all the bolts you might find problems when the engine cooled down, most likely the steel bolts would pull the aluminium threads out as they cooled and contracted. However this is unlikely to happen, as no-one wants to be playing with fasteners when they're hot.
