 spinners >
spinners
spinners
Old 04-01-2009 | 11:42 PM
Default spinners
When do you switch sizes on spinners like say there is 2, 2 1\4 2 1\2 2 3\4 3 inch and so on what size spinners go with what engines i have a 55 ax and a 75 ax what spinners whould each take and why would i use different sizes on the two?
Old 04-02-2009 | 12:07 AM
Jetdesign's Avatar
My Feedback: (8)
Default RE: spinners
Use the spinner that looks right on the plane. Doesn't have much to do with the engine.
I have a 2" spinner on my Venus with a 55AX, I had a 2.25 inch spinner on a 46AX on my trainer, and I have a 2.5 inch spinner on my 120AX and a 2.75 inch spinner on my 110FZ.
Sometimes you have to widen the slots to get the prop to fit, or you can get spinners with larger cuts. I got the "120 cut" for my 110 four stroke which fits larger props.
Old 04-02-2009 | 12:20 AM
Alex7403's Avatar
yes spinners you choose by the plane.
Old 04-02-2009 | 11:45 AM
any good secrets on the best way to trim spinners without getting them too bad out of balance or does it matter
Old 04-02-2009 | 12:09 PM
Jetdesign's Avatar
My Feedback: (8)
I have found that hand files work the best. I tried quite a few attachments to my dremel and a mini hacksaw, but nothing works as quickly or smoothly as a file. You can draw lines where you want to file down to with a fine point sharpie for some guidance.
As far as balance, that tends to be a personal preference in this forum. Some say the weight is too close to the axis of rotation to make much of a difference, others say everything spinning at 10-16000 rpm should be balanced as best as possible.
I bought a Tru Turn spinner because they either come cut for a large prop, or they will custom cut for you for a minimal charge, and they will send it to you balanced. I don't have the means to balance spinners otherwise I would balance all of mine.
